I have the Intex SWG new model and the water level in the oval chamber is only 3/4 of the way full. If i pick up the unit the air will leave but within minutes it fills with air again. Is this how the other units look?
Another question about the removal of the copper ionization piece. I have read reports were people say they remove the copper and or just unplug it. You can't do that I unplugged it and water leaks out of it where it was plugged in, and you can't remove the copper either because it leaves a big hole in it. What I ended up doing was using one of the Intex plugs under the cap with the wire unplugged, but the copper is still in the unit as I didn't have anything to plug up the hole if you remove the copper. How has this been done?
I have attached a picture of the oval unit so you can see what I mean, does your not fill this entire chamber?
