Results 1 to 9 of 9
Thread: losing water
    losing water
    This is only my second season having a pool. I live in Georgia (USA) and have a question about pool water loss. Is it typical having to fill the pool after swimming in it (kids jumping around - in and out - on the diving board) plus 95+ degree heat. Seems I lose about 1-2" water every 4-7 days. It rained last night for the first time in almost 2 months and yesterday I had 6 kids (3 BIG ones) swimming and even with the rain I was down about 1/2-1".
    Thank you!
    Re: losing water
    If it is hot and not humid you can lose 1/4" a day, add splash out and 1-2" in a week is plausible. If it is very humid there, than not so plausible, but not out of the question depending on the kids With lots of kids playing and splashing it will be difficult to be sure either way.
    Re: losing water
    I appreciate that - I just seem to be putting water in my pool every few days and it seems like a lot - but when I actually measured today it was only about 1/2 inch. Maybe I'm worried too much When should I be concerned - how much water loss?
    22,551
    Re: losing water
    If you lose more than ½" per day then I'd do the bucket test just to check. less than ½" it's probably just evaporation or splash-out.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Re: losing water
    Is it possible to be losing water through the automatic cleaner? I'm a bit concerned - we had a TON of rain here in GA last night - I left my pump and cleaner running for about 12 hours and I woke up to about a 1" loss of water. I put the hose in the pool to fill the water loss - turned on the pump with just the "bottom" pool drains on and the cleaner - 3 hours later it looks like I have more water loss rather than more water in the pool! UUGGH - how can I find out for sure? I JUST moved into this house last year - we have a 1 yr warranty that expires tomorrow - and I'm wondering if this may be covered - and how do you go about detecting leaks if there are any?
    22,551
    Re: losing water
    Take a bucket and fill it 2/3rds with pool water. Sit it on a step in the pool and mark or measure the water level in the bucket very carefully. Then mark or measure the level in the pool very carefully. Check the levels tomorrow and see if they both lost the same amount. If the pool lost more than the bucket you have a leak. Once you figure that out we can narrow down where it is.
    If your warranty expires tomorrow, I'd call them today and tell them you have a leak. That way at least you've notified them during the warranty period.
    Re: losing water
    I'm thinking it may be my cleaner - how do they replace the lines for that....digging up my yard??
    22,551
    Re: losing water
    If it works out to be the lines, then yep, digging is required. Most of the time it's not underground that's leaking.
    Jul 2008
    McDonough, GA
    98
    Re: losing water
    On my 24' round thats about what I lose in a week
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
