Results 1 to 12 of 12
Thread: Help, Post Storm Clean Up, step by step instructions needed
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    We had a storm early this morning and one of my palm trees blew into the pool. Yes the whole pot including the dirt was in the pool I had no time to do anything except recue the plant. I had the wife put in 2 gals of bleach so far. I will not be able to do anything till this afternoon, so I am asking for some step by step directions in cleaning up my pool. All thoughts are welcomed
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Re: Help, Post Storm Clean Up, step by step instructions nee
    It is fairly straightforward, get everything out of the pool anyway you can and keep the FC level higher than normal until things return to normal.
    You should be able to get a fair bit of it out with a leaf rake. Anything the leaf rake won't pick up you can vacuum up. You will probably need to stop vacuuming ever so often and backwash/clean the filter.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    How high would you suggest?. I normally keep my FC at 10
    30,419
    What's your CYA?
    Apr 2009
    Burlington, ON, Canada
    344
    You could also try vacuuming on waste, and bypass all that junk getting into your filter, thus not having to backwash.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    What's your CYA?
    Last time I checked it was 80
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    Quote Originally Posted by rcy
    Good idea but I do not have a vaccum. Maybe my shop vac will work
    Apr 2009
    344
    How do you clean your pool without a vacuum?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    Our pool does not get dirty. We have a screened enclosure
    Apr 2009
    344
    Nice!!
    A hose and vacuum head probably won't break the bank if you have a lot of debris in the pool from the planter. Otherwise I don't know how you'll get the soil off the bottom??
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,055
    Nice!!
    Actually I have a polaris 280 that I used once and then put it back in the box. I guess this will work
    Apr 2009
    344
    Probably. You'll just have to use a pole or something to keep pushing it around to where you want it. I think that thing has it's own filter bag, right? You might not have to vacuum on waste if it does.
