Results 1 to 7 of 7
Thread: Hayward Heater Help
    Sep 2007
    middle tennessee
    38
    Hayward Heater Help
    Have a Above ground pool that I installed a Hayward 1001 natural gas heater on..has worked fine..
    well it started making a strange sound like,,,popcorn popping when running????Took off the top
    cover while running and it's not in fan,,it seems to be comming from inside the big metal
    sleeve that the input water goes in and then exits the other side ??..works fine,,just makes
    that popping,,ratteling sound in that tube,,any ideas?
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    Im by no means an expert in these things-- but recently found out a problem with my Pentair heater--
    Mine has a water flow valve in the I/O manafold. Its a spring operated disc that regulates the cold water flow. APparently it keeps the "correct" water pressure/flow through the heater coil-- too fast and the water doesnt heat well. Too slow and it over heats.
    I kept hearing this rattling sound when the pump went off. It was coming from the I/O manifold on the heater.
    See my post about my heater for more details abou the heating problem-- but..... you might check to see if your unit has such a device.
    ADDITION-- The flow valve I removed was toast !! The springs were gone, the frame almost gone. THe previous owners had an inline chloinator installed just past the heater output. When the pump was off, high level CL water would seep back into the heater *shaking head at the builder*
    - Reji
    Sep 2007
    middle tennessee
    38
    8) Off season,,getting ready to tear into my heater....I think i mght be looking at a,WATER PRESSURE switch,,
    or a HIGH LIMIT switch causing my noise?..any help?
    South Central NJ
    3,192
    Any air bubbles in the return flow?
    Owner of - PoolGuyNJ LLC
    Ft Lauderdale, Florida
    1,455
    pooldog, It may be the water boiling too if you don't have enough water flowing through the heater. Usually the pressure switch will catch it, but if you're having pressure switch issues, it will not shut down to protect it.
    As mentioned, it may be the internal bypass valve is corroded or stuck opened. While you have the system down, there should be a flange on the end of the in/out headers that will allow you to remove the spring and shaft that holds the bypass valve.
    Hope this helps.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Re: Hayward Heater Help
    This answer is for a H400 propane heater, but it may apply to you as well...
    The banging, creaking, pinging, and shaking is caused by insufficient flow through the heat exchanger, and the water is flashing to steam. It is not safe to operate the heater when this is happening.
    The reduced flow can be caused by the following conditions:
    - dirty filter/pump basket (you would not have sufficient flow in more than just the heat exchanger if this is your problem)
    - bypass valve in front header stuck open (most likely)
    - thermostatic control valve in front header stuck closed (can remove it to test)
    - obstruction in piping/heater such as pool vinyl, rock, frog, etc. An obstruction in the heater can be observed by removing the rear header and turning on your pump (heater off). Flow should come out of all tubes after a few seconds).
    - eroded rear header internals (my problem this time). There is a divider plate molded as part of the rear header that wears away over time (10 years for me). If eroded enough, it will allow flow to travel from one side of the rear header to the other, bypassing heat exchanger tubing.
    - worn pump impeller (you would not have sufficient flow in more than just the heat exchanger if this is your problem)
    Jim Hoerner
    Oct 2010
    Georgia
    317
    When was the last time you backwashed your sand filter?
    Does it make the same sound when the pump is on high and low speed?
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
