Thread: Ultrabright
    Hark's Avatar
    Mar 2011
    Phoenix, AZ
    24
    Ultrabright
    What do you all think of Ultrabright? What effects does it have on the chemistry?
    10,000gallon, IG Pebble Tec, Pentair Intelliflo VS+SVRS 3hp Variable Speed Pump
    Hayward Cart Filter C4025, Hayward Pool Vac Ultra, 1 vac line, 1 skimmer, 2 Main Drain, 3 returns, 2" plumbing
    TF100 Test Kit.
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Ultrabright
    You may find this link of interest: anyone-know-what-s-in-leslie-s-ultra-bright-t24670.html
    I don't think Ultrabright is necessary, although I was given a bottle of the stuff. Pool store recommended 'maintenance' doses...but then again I stopped listening to their advice a long time ago. And so the bottle of Ultrabright sits on the bottom shelf.
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Jul 2008
    McDonough, GA
    98
    Re: Ultrabright
    Ultra Bright worked very well for me. My pool had red clay dirt in the water after installation and after holding 3 nights on the overnight chlorine loss test, I used it and my pool went from barely seeing the vacuum head on the bottom to perfectly clear in one day. The skimmer sock was barely catching any of the dust before I started to turning the sock completely clay red and having to cleaning it 3 times on that day. I used 2 doses, but I think I should have waited 24 hours to see if I needed the second dose.
    With that said, on Monday I added 1 ½ lbs of CYA through pantyhose in the skimmer and I haven’t registered any increase yet. I don’t know why.
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Ultrabright
    Quote Originally Posted by BBailey
    It can take 5-7 days for CYA to fully dissolve and register on tests.
    Hark's Avatar
    Mar 2011
    Phoenix, AZ
    24
    Re: Ultrabright
    Quote Originally Posted by Voodoo_Pool
    When I was "Pool Stored" last year (First year pool owner) I had bought a bottle on their advice. I used it once and it worked pretty well, but then again I was putting in whatever they told me to put in. BBB method all the way now.
    TF100 Test Kit.
