Results 1 to 10 of 10
Thread: What's the best low-cost solution?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I have the pool listed in my sig. It came with a vacuum hose, a pole and some nets, and that's about it. I have a fair amount of dead algae to get off the floor and would like to be able to vacuum it up. I can spend some money, just not a gazillion dollars on a Mr. Roboto. Please advise what I might be able to do with a pump and filter solution. I would like to maybe get a vacuum head but does that mean the water flies out to waste when I'm running it?
    Alternative suggestions welcome. Thanks!!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: What's the best low-cost solution?
    I'd sure try the inexpensive vacuum head first. You can always use one any way. Just vacuum in normal filter position and then backwash.
    22,551
    I'd do what Woody suggests. Just vacuum to filter then backwash it out good. I always vacuum to filter, it wastes too much water vacuuming to waste. The only time I vacuum to waste is after one of our torrential rains and I need to dump the water anyway.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Thanks both. I checked out a couple of youtubes about the steps for sending to filter. Apparently it's the most traditional of approaches - duh, you gotta learn at some point! I thnk I was just concerned that the filter was strictly designed for light cleaning. I'll keep an eye on the pressure guage.
    Do I need to rinse after backwash? I have a feeling that, at first, I will be repeating the cleaning phase many times to get the initial debris out.
    22,551
    Yep, rinse every time after a backwash.
    So how's Daisy doing? LOL
    No advice here because we are looking for a cleaner too but, I LOVE ONSLOW!! Ha, still one of our family's all time fave shows and characters
    21x40 - 28000 gal Kidney w/swimout, bench, Aqua Comfort Heat Pump, AquaRite Plus SWG, LED, White plaster/blue tiling, Cartridge Filter, 1hp pump, Polaris 380
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Quote Originally Posted by maggiem
    Oh, nice!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I bought a cheap vacuum head at Lowes, along with the hose, and found a sink tailpiece that works to couple the hose directly to my suction port in the bottom of the skimmer. It's worked fine for a year.
    Oct 2007
    Parkland, FL
    752
    yea, but if its algae, you likely gonna throw the filter out after one time, and algae will clog almost instantly. i'm using a poolbuster to try to get algae off the bottom, bag is clogged in 30 secs, rinse and repeat.
    I put a brand new filter in just filtering and it clogged in less than 6 hours.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    You can get a cheap robot or even a Pool Blaster so that your filter isn't affected.
