Results 1 to 9 of 9
Thread: Floating dead algae
    Floating dead algae
    I have a 16x32 inground pool about 28000 gallon and located in Arkansas. When we took the cover off the water was green but after a few days of shocking it is clear and sparkling. I do have alot of dead algae floating in the water. Is there anthing I can do to get rid of it or do I need to be patient and let it filter out. Love this website, thanks so much for helping me. Ann
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Floating dead algae
    Welcome to TFP Keep the water at shock level and keep the filter running 24x7.
    22,553
    Welcome.
    What type filter do you have?
    I have a sand filter. Changed sand last year and cleaned sand this season.
    Feb 2008
    Denton, TX
    5,061
    So, your FC holds overnight and your CC is 0.5 or less? If so, you should just backwash as needed, indicated by filter pressure rise.
    22,553
    You can add a little DE to your filter to improve the filtering and that may help clear the water a little faster.
    Sep 2009
    Greentown, IN
    914
    Stand your ground.. You're on the home stretch!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Maybe some clarifier?
    20' x 40' / 33,000 gallon / IG / Vinyl
    200lb sand filter / 1hp pump
    4hrs full sun with about 45 min part sun before and after
    22,553
    Clarifier is sort of a last resort. We like to make sure everything is killed and the equipment is working properly before we recommend trying it. The biggest reason is that there are as many instances of it not working as there are where it did. Granted, when it does it's pretty dramatic.
