Thread: TA 160. Problem?
    May 2011
    Wichita, KS
    38
    TA 160. Problem?
    I know a TA of 160 is too high. But, pool school says not to lower it for the sake of lowering it. How do I know if I have a problem?
    Filter: sta-rite cartridge
    pool: In-ground vinyl
    pump: ?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,623
    Re: TA 160. Problem?
    Only if you have a problem with wild PH swings. Or going up or down too quickly.
    If your PH goes up annoyingly quickly, or makes sudden jumps up, then you should lower TA. You might also need to lower TA if your CH level is too high.
    May 2011
    Wichita, KS
    38
    PH is at 7.2. I pointed a jet up to aerate. As I understand, that should raise PH and lower TA, is that correct?
    pump: ?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It will only raise PH. Acid lowers both TA and PH, its the aeration that raises the PH back up - so you can repeat the acid addition process that eventually lowers the TA into range.
