Results 1 to 16 of 16
Thread: Is my Chlorine too high??
    Jun 2011
    NC
    7
    I am hoping someone can help. My pool turned green a few days ago and Duraleigh assisted me on how to shock my pool. I did that and within about 24 hours my pool turned from green to blue just as he said! Anyway, I just tested my water and I think my CYA is kicking in because my chlorine levels didn't go down today for the first time. However, I did add an extra large bottle of bleach to my pool this morning since my TC was at 5 and my ph was at 7.2. I tested my CYA about 30 minutes ago and it is at 27 and my FC is 20 and I have no CCs, so my TC is 20. This leads me to believe my Chlorine levels are way too high and not sure how to bring them down unless I add more water (which I do have room to do), but I do not want to make things worse.. I have not added Borax to my pool as of yet. Please advise...
    Thanks in advance for your time!!
    Tammy
    Edited to add:
    FC - 20
    TC - 20
    pH -7.2
    TA - Did not test
    CH - Did not test
    CYA -27
    Intex 20x48 AG Ultra Frame Pool (7947 gallons at 90% full) - Vinyl liner
    Intex Saltwater Sytem (CS8110)
    Intex Filter Pump (635T) 1500 gph - Type A cartridge filters
    Pool has been set up since Memorial Day 2011
    Using the TF-100 Test Kit
    30,133
    Re: Is my Chlorine too high??
    No, your FC is just fine. Leave it in there and it will come down on it's own.
    What CYA target are you shooting for?
    What does your water look like?
    Your pH is fine where it is....don't add any borax.
    Add more water if you'd like it deeper but there is no chemical reason to do that.
    22,403
    Ditto what Dave said. A little bit of sun today and your FC will come down. If you've passed the OCLT just let the FC come down on it's on. It's safe to swim at shock level fro ou CYA once you've passed the OCLT.
    Jun 2011
    NC
    7
    The water is blue, but you can barely see through it.
    Last night's FC: 20
    Today's FC: 16 (there was some sun shining on the pool when this was done)
    What should the ph target be at this point? It is holding right at 7.2.
    Thanks again...
    Jun 2007
    NC
    255
    Quote Originally Posted by cj7girl
    Last night's FC: 20
    With the sun that HAD BEEN in NC the chlorine will burn off fast, especially with a CYA of 27.
    What CYA level were you shooting for ?
    It'll be difficult to do correct pH testing if the FC stays at 20... which it won't according to the weather forecasts!
    What part of NC are you in?
    Terry in NC (outside of Kernersville)
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    30,133
    Continue to shock. Bring the FC back up to 20ppm this afternoon anytime. Then bring it back up to 20ppm tomorrow AM, too. Run the pump 24/7. keep the filter clean.
    Disregard the pH until the shock process is complete. That will be when.....
    1. Your water is crystal clear.
    2. You lose less than 1.0 FC during the FC overnight loss test (OCLT)
    3. Your CC's test is .5 or less
    You have a ways to go.
    Jun 2011
    NC
    7
    Thanks, guys!!
    Terry, I am outside Raleigh.
    Dave, thanks, that helps a lot since I didn't know when to quit shocking...
    Jun 2011
    NC
    7
    I shocked my pool back to 20 last night and this morning it was still at 20. The pool is clear and I can see the bottom, but it's still a little cloudy. Does this mean I can quit shocking now? If so, what do I do now? If not, then what do I need to do?
    Thanks!!
    Aug 2010
    Dallas, TX
    4,052
    What is your TC or CC reading?
    Jun 2011
    NC
    7
    FC 20.5
    CC 0
    TC 20.5
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks!!
    You are done shocking when you meet three criteria. See the red line in my sig
    You're done SLAMing when:
    Jun 2011
    NC
    7
    Thanks so much for the quick response!!
    Now, that I am done with shocking I am ready to level out my numbers, correct?
    I was reading some threads on SWGs and I am guessing the numbers below are going to be my goals from this point on, right?
    FC: 3-5ppm
    PH- 7.5-7.8
    TA- 60-80
    CH- 50-300 vinyl
    CYA- 70-80
    Borates- 30-50 ppm (Where can I purchase borate test strips?)
    Butterfly's Avatar
    South Carolina
    10,045
    If your pool is still a little cloudy, I suggest you shock at least another night.
    The water should be clear, not cloudy.
    Aug 2010
    Dallas, TX
    4,052
    You don't have to do borates. That's an option. You can get the strips from tftestkits.net
    Jun 2011
    NC
    7
    Okay, we added more bleach last night after the sun wasn't shining on the pool and here are the tests we did:
    Before we shocked
    TC: 15.5
    CC: 0
    An hour later this is what we got:
    TC: 16.5
    CC: 0
    Midnight:
    TC: 15
    CC: 0
    This morning:
    TC: 16
    CC: 0
    So, what do you think? Can the numbers actually go up?? I can see the bottom of the pool and it isn't as cloudy as it was. Do we need to shock it again?
    Thanks!
    30,133
    No, but that's just a small testing error, dont worry. (your actually testing FC and not TC but it's not relevant to your questions.
    #1 - How does your water look this afternoon?
    #2 - Did you pass all three of these guidelines?
