Thread: Itchy dry skin from???
    brewtus's Avatar
    May 2008
    Knuckle of the Thumb in Michigan
    16
    First, the test Taylor Test kit results for today:
    pH - 8.0
    TA - 180
    FC - 6.0
    CC - 0
    CYA - 55
    15 x 30 above ground, 13,500 gals.
    I took a quick dip tonight, then tested FC (1.5), I added liquid chlorine and had dinner. While eating I noticed my skin was getting dry and itchy. I mentioned this to my wife, and she said that our sons hair seems to be 'dry' lately after swimming also.
    I just tested the water again and got the above results.
    The pH has been slowly rising since 5/24 from 7.4 to 8.0 today. I only add bleach (10 to 12.5%) to keep the FC around 4-5.
    I'm going to bring down the TA and pH this weekend with aeration and Muratic Acid.
    The CYA at 55 is a little surprising, since I've tested this several times in the past month, and each time the results were 40.
    Which of these could be causing the dry skin/hair problems?
    I don't know enough to even know what I need to know.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: Itchy dry skin from???
    Just add the muriatic acid to lower the ph down to 7.2 Doing that over time will drop the TA. You don't need to areate.
