Thread: Polaris with green water?
    Jun 2011
    Platte City, MO
    5
    Well first let me thank you for such a well constructed forum, with tons of information and resources related to pools.
    I know there have been many questions addressed regarding green-to-blue pools, however I have yet to find one that ties in automatic pool cleaners (I’m sure there is a post…I just didn’t look hard enough).
    Therefore, my question is would utilizing my Polaris expedite the cleaning process by putting the sediment into solution allowing the filter to do its job?
    Chemical numbers are listed below. Thanks, I appreciate any insight.
    -Eric
    Temp: 80
    Saturation Index: -0.2
    TDS: 1000
    CYA: 10
    Tot. Chlorine: 10
    Free Chlorine: 10
    pH: 7.5
    Tot. Alkalinity: 120
    Adj. Total Alk: 117
    Tot. Hardness: 110
    Eric
    30K gal, IG-vinyl, 1.5 HP Pentair Challenger pump, Pentair Triton II TR100 sand filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Polaris with green water?
    If it's just algae at the bottom, then let 'r rip
    Oct 2010
    Georgia
    317
    Eric
    Running the Polaris for a few hours each day can actually speed up the overall process. The Polaris can sweep the bottom and expose any live algae to the chlorine rich water. Removing any leaves or debris can also expedite the cleanup process. In addition to running the cleaner, also brush the sides, around the light, and around the step(s).
    The down side is that it may be difficult to notice daily progress when the water is constantly churned.
    PSG
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Jun 2011
    Platte City, MO
    5
    Thanks all – I could’ve ran Polaris and filter day and night and it wouldn’t help. I reviewed other posts and realized the problem was with the filter. I just purchased this house, and I’m scratching my head as to how the previous owners were able to keep the pool clean with the numerous holes (approximately 30+) and broken internal plastic (not sure what they’re called…grids, ribs, fingers). Well, after a spool of thread and three sticks of hot glue...the pool is clear. The method is definitely effective (probably degrades the efficiency, as the hot glue takes up the surface area the DE media could attach too). I think I will limp through the season this year and order new fingers next year.
    Eric
    22,553
    Glad you found the problem and was able to patch it. Now, at least, you can plan on a new filter or internals for next year.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
