Thread: Spa pump operation
    Jun 2011
    New Jersey
    149
    Spa pump operation
    Hey Guys, I read some of the Pool School and hope that I am not asking the wrong question. I understand I might need to show pictures but as it is dark outside I am hoping someone might have an idea without it. I have a pool with an attached hot tub. It has a small overflow where water gets in and out of the spa into the pool. I have a timer that turns on the pool filter and vacuum but can not figure out how to operate the filter for the spa. There is a switch for the spa pump but I can turn it on or off manually only as far as i can see. Does this make sense? and do I then need to manually turn it on and off and if so how different would this be from the pool? I am new to pools, just bought a house in april and had it opened last weekend. I have a salt water pool with polaris vaccuum and Jandy filter, chlorinator and all that other stuff. It is a salt water pool.
    Free Form Gunite Saltwater Pool, 29,000 Gallons, Jandy DEL60 Filter, Jandy AquaPure 1400 Chlorinator, Polaris 380 Cleaner, Attached HotTub.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Spa pump operation
    Welcome to TFP!
    The spa should spill over into the pool during normal operation; that way the water in the spa is continually circulated and filtered. A picture of the equipment area would help, if you need some more assistance figuring it out. Sorry it took so long to get you a response!
