Thread: Polaris Autoclear Plus cell going bad??
    Just got my system up and running (foreclosed home purchase). The panel on my autoclear plus is reading now 2400ppm, 5.1 amps, and 22.3 volts. Of course the LEDs on it are reading very low salt and it will eventually shut off at 1500ppm. When I tested the salt level just a few minutes ago, I got a reading of 3120 on the strips. The manuals for the system are horrible from the ones I found on the internet. Is there some kind of calibration or something I need to do for the readings to be more in line? I set the temperature to 90 degrees when my water is 88. The run time and water temp are the only things I can find to set.
    Also I don't know the age of the cell. The house was built in 2002. When I looked inside the cell it looked clean.
    31,000G IG vinyl 20X40 True L. Hayward 1.5 superpump, Autopilot Pool Pilot Digital SWG, Hayward Model S244T 300lb sand filter, TF100 kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Polaris Autoclear Plus cell going bad??
    Sounds like the cell may be on the fritz; "low salt" when the salt level is fine is a common symptom.
    when i bought my home it had the same system. Never had a pool before, but found out the hard way about checking the stabilier level. If you haven't done that yet.... don't add salt.
    Oct 2009
    3,899
    Stabilizer levels won't affect the salt reading...sorry.
