Results 1 to 9 of 9
Thread: I have been the pool store route
    I have above ground pool 24'x52" , I think 12,500 gal. I have been the pool store route , water never cleared up .It went to a brown color! I ve been reading threads on BBB ,,ok for the past five evenings I have been adding bleach 6% . Ive probably added around 18gals. The water is like bluish and cloudy , so Im making progress ! Question is what do I do now ? In the beginning I added about 1/2 gallon muratic acid. I think I pobably need more . I bought a sand filter w/1&1/2 hp motor benn running it non-stop.
    TH 1000
    FC 0
    PH 8.4
    TA 120 /180
    CYA maybe 10
    So please advise me . I surely will appreciate it
    ruby1115
    Re: I have been the pool store route
    Welcome to TFP!
    Start by lowering your PH down to around 7.2 to 7.4. You should never let PH get above 7.8.
    You should also raise CYA to around 40 to 50. With CYA as low as it is right now you will be losing most of your chlorine to sunlight each day.
    From your description you have most or all of the algae dead and are mostly waiting for the filter to finish cleaning up the water. As long as the water continues to look better each day you are on the right track.
    Look Im sorry if I stepped on toes I have never used this site , and if I did something wrong tell me how to fix it !!!!
    So do I keep using bleach on a daily basis ? And if so could you tell me about how much ?
    Thanks ruby1115
    30,421
    I'm not sure what makes you think you stepped on anyone's toes (you haven't). What you need to do next is to go into Pool School and read and understand some of the basic articles there. "ABC's of Pool water Chemistry is a good start." Then, read "how to shock your pool.
    Your first step should be to get the pH down as Jason suggested. Post back when that is done.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    How can you be tired of following the pool store advice already? It's only the middle of June! :P
    If you want to be free of their evil influence, you'll need information. The two places to get that are: Pool School; and your own, proper, test kit. With the facts, you can let Pool Calculatordo the number-crunching and add what it says to add. Just that easy.
    If you're getting test results from the pool store, they'll have the opportunity to whisper in your ear while their hands are deep in your wallet. If you are using test strips, you're not much better off, except the colorful displays aren't right there tempting you to buy snake oils.
    My advice: order a test kit, adjust pH, and start reading.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Ruby and welcome to the forum
    To help things along, it will be good if you add your pool and equipment specs in your signature.
    Go to User Control Panel (top left, under TFP logo), select Profile, the Edit Sig.
    You're done SLAMing when:
    I fired my pool store this year too!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Hi Ruby. It sounds like you are doing great so far. Yes, do keep adding bleach. You're getting good advice here to use the pool calculator web site to determine how much bleach, CYA, and muriatic acid to add.
    I suppose the other thing to mention is to keep an eye on the psi reading on your sand filter, and do a backwash when the psi gets too high (as in, more than 10 psi over what it reads after a backwash). Of course, you likely already know that from reading pool school.
    17' x 25' x 48" Laguna "Portable" Pool (~12,000 Gallons)
    Intex 8111 SWG, Pump, and Filter
    3 Fafco AGP 4 x 20 Solar Bear Panels
    Dirt Devil "Pool Boy" (Pool Rover Jr.)
    BBB and a SWG make my pool care really E-Z
    Sep 2009
    Greentown, IN
    914
    Hang in there... these guys and gals are great at helping out. Many of them have been where you are and understand exactly what you're going through. You've gotten great advice already. Get started on their suggestions and post back how things are going.
    Welcome to the forum and enjoy your soon to be clear pool!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
