Results 1 to 11 of 11
Thread: Which direction to replace handle?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    This question may be a stretch but...
    I received a repair kit for my Jacuzzi multiport and have finished replacing the diverter/spider gasket assembly among other things. I had to put the housing assembly back together to push the center stem of the diverter high enough to reattach the handle (secured by a roll pin) up because of the spring's pressure.
    One problem. The handle can go on one of two directions.
    Underneath inside the center of the handle there is a little notch that apparently pushes on the diverter stem.
    The diverter stem also has it's own notch on one side. On the other is a diagonal taper.
    My question: Should both those notches make contact with each other of should the notch inside the handle face the diagonal side of the diverter stem?
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Jul 2008
    McDonough, GA
    98
    Re: Which direction to replace handle?
    I had the same problem and thought I had it on right until I put sand back in the pool. lol Good luck
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    In one direction I can put the roll pin in one way without trouble. This makes me wonder because usually there is upward pressure on the handle and in this case it was still loose. The other way (where both the inside notches are against each other) makes it very difficult if not impossible to put the roll pin back in so I may have no choice but to at least try it the first way.
    Jul 2008
    McDonough, GA
    98
    Be ready to cut it off right quick if you have it wrong. If you have it right, go grab a lottery ticket
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    It goes on easiest when the tabs (notches is probably not the right word) are on the different sides. I, for now, will take that to mean they are not to interfere with each other during assembly.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Guess I better get that lottery ticket. After a year of prepping, researching a gazillion posts on this forum, and a sizable investment rebuilding filter and buying this-and-thats, tonight the system is up and running! Lots of misadventures along the way (especially today) with water mishaps but I've now been able to go through a few backwashes (while testing ratty vacuum head) and pressure is at 15 psi when running. Good deal!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Congratulations, Onslow.
    Once that pool is clear, I want to see some pictures with your sister-in-law Rose in it.
    You know, two years ago, while vacationing in England, I actually stopped by the Bucket Residence and Onslow's council house.[attachment=0:nkgmros8]onslowshouse.jpg[/attachment:nkgmros8]
    Jul 2008
    McDonough, GA
    98
    Congratulations now get the pool clear and GO SWIMMING!
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Richard,
    What does the green sign in that picture say?
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by Onslow
    Richard,
    It says
    YOUR MOVE
    For Sale
    blurry552255
    your-move.co.uk
    Just a few doors away from the Onslow house is this sign:
    [attachment=0:37fjrp5s]sign.jpg[/attachment:37fjrp5s]
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    So Onslow and Daisy's house is for sale? Thought it was public housing but maybe they do it different there.
    Incidentally I contacted the company looking for the hat he wears (a road paving company apparently). I received the following response a week or so later. I know our money is not the same but it was too rich for my wallet.
    Hi,
    Yes we can supply a cap.
    Please send $50US Cheque or money order to
    Fulton Hogan
    11 Main Road
    Fairfield
    Dunedin 9054
    New Zealand
    We will dispatch on receipt of payment, with full address .
    Regards Dave
    Fulton Hogan is a dynamic, diversified contracting company active in New Zealand, Australia and the Pacific Basin. Constituent divisions represent a broad range of products and services in the roading, quarrying and civil construction sector, and hold strong positions in their respective markets. http://www.fultonhogan.com
    Get on the Road to Success. For career opportunities within Fulton Hogan navigate to http://www.fultonhogancareers.com
