Results 1 to 8 of 8
Thread: Skimmer weir door hinge position
    May 2011
    Los Angeles, CA
    228
    Pardon my ignorance in this matter but...
    Is a skimmer weir door hinged at the top or the bottom?
    Wha???? do i hear you guys laughing?!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Skimmer weir door hinge position
    I'm betting if you go take a quick look at yours, it will be readily apparent.
    May 2011
    Los Angeles, CA
    228
    The only problem is, I dont have a door at all... my skimmer has/had many missing parts... it didn't even have a basket in it when i brought the house!
    38,371
    OK, I won't pick on you.
    It hinges on the bottom (at least all the in-ground pools I have seen do). Mine had a little plastic strip that slipped into a slot and was then held there by a few screws. Alternatively, they sell replacement doors that are are spring-loaded, so the bottom is held in place by friction with the sides of skimmer. Those are pretty cheap, although I also found the door to be a little flimsy.
    22,551
    Bottom. It floats just under the surface when the water is flowing across it to create a faster surface flow so the floating debris is drawn into it .
    May 2011
    Los Angeles, CA
    228
    Thanks! you all are awesome!
    Apr 2009
    Burlington, ON, Canada
    344
    Well, you learn something new every day. I always thought the door was just to prevent basket goop from floating back into the pool when the pump is off. Interesting.
    So, now I'm thinking, does it make a huge difference how high up the skimmer face the water is (i.e. if the water level is very high or low up the face of the skimmer, will the flow across the door be affected one way or the other)?
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    22,551
    Quote Originally Posted by rcy
    As far as the flow across the weir, unless it gets very high (above the opening) or very low (below where the weir can move) it really doesn't affect it much. What usually happens, is that when the water level gets low, the pump will pull water fast enough through the skimmer to create a vortex and suck in air. Raising the level an inch or two will usually prevent that from happening.
