Thread: Filling A Hasa Chlorine Injector
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    I've installed the 4Gallon Hasa Chlorine Injector, upgraded to the 3/8" kit, works great. The issue that I've come across is how to add the chlorine in. Do you put in one gallon and wait a few days, then put in another one? I find that when it gets low, the only way to add the 4 Gallons is to drain some out of the unit.
    So I'm just curious as to how others add chlorine to their injectors.
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    Re: Filling A Hasa Chlorine Injector
    You can add several gallons at once as long as you do it slowly enough and the pump is running. The unit will drain down as you add chlorine, it just takes it a while.
    Aug 2010
    Dallas, TX
    4,052
    Here's what I do, while pump is running:
    I put the valve wide open
    I hold the intake float UP (closed) with my hand
    I then slowly pour in the chlorine, one 182 oz jug at a time.
    It gets pretty heavy, but as long as you put the valve completely open you can pour them in fairly fast. It doesn't seem to significantly raise FC in the pool since the water is coming off the top, not using the chlorine off the bottom.
