Results 1 to 9 of 9
Thread: CYA dropping - add stabilizer w/ pucks?
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    This is a new gunite pool. I don't have my test kit yet, but it should be here any day now.
    On Saturday the pool store tested my water and said it was:
    Chlorine - 5.0
    ph 7.9 (they had my add one pint of muratic)
    hardness 350
    alkalinity 80
    cya 55
    Today they tested it and said:
    Total Clorine .7
    Free Clorine 0
    ph 7.3
    harness 344
    alkalinity 58
    cya 28
    Over the weekend we had lots of swimmers and I added some water because of splashout, but not lots. Should I add stabilizer to the water? I'm using pucks for chlorine. The pool store recommended I add 4 lbs of stabilizer now.
    My chlorine at 0 is obviously a concern. I'm going to shock with bleach. But why would it be at 0 with the automatic chlorinater and pucks?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Aug 2010
    Dallas, TX
    4,052
    Re: CYA dropping - add stabilizer w/ pucks?
    The pool store is notorious for giving bad CYA numbers. I wouldn't add any right now unless you are using a salt water chlorine generator. You need to add some liquid chlorine (clorox) immediately, and a good test kit would be extremely beneficial to you.
    By the way, the temps and sun we are having right now is burning off chlorine FAST.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I just added 182 oz. of 6% bleach and added 100 oz. of baking soda. I also turned the clorinator dial from 3 to 5.
    Hopefully the mailman will have my test kit tomorrow.
    Jandy 2 speed pump
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by texasdad
    Because you are losing your FC faster than the slowly dissolving tablets are giving you. You need to shock and use bleach to accomplish this. Bleach is immediately available all at once and that makes it good for this purpose.
    If you haven't already, please order a decent test kit from www.tftestkits.net. You pool depends on your ability to do your own testing and for it to be suitably accurate.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Quote Originally Posted by RobbieH
    Been cold and cloudy here. Good news, FC is steady.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    The Fed-Ex driver dropped off the Taylor k-2006 today.
    Results I got are:
    FC 3.0
    PH 7.6
    TA 130
    CYA 50
    I'll redo all of the tests later today to double check, this is my first time for a few of the tests and I wasn't certain on the CYA...... How often do you check the CYA; the test kit only has enough for 3 tests?
    Jandy 2 speed pump
    Butterfly's Avatar
    South Carolina
    10,045
    You can pour the CYA mix back into the bottle and redo the test several times to compare.
    Also, here's instructions w/a visual from Taylor that helps us. Scroll to bottom for pics:
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    When you post back w/test results, please be sure to include your CC# from your FC test & CH #.
    How old/new is your pool?
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    You can order your refills from http://tftestkits.net
    Get a bigger bottle of CYA reagent. You can refill the tiny one by prying the tip out, if you want to keep it all tidy in its little box.
    Jun 2007
    NC
    255
    ... Taylor k-2006 today.
    Results I got are:
    FC 3.0
    PH 7.6
    TA 130
    CYA 50
    It can take up to a week to register any increases in CYA so the weekly check makes sense.
    Keep the CYA/Chlorine chart handy (as in your kit) http://www.troublefreepool.com/pool-...ya_chart_shock. It'll show you the minimum chlorine levels and the shock levels for the various CYA levels... and, it's in Pool School !
    With a CYA of 50 your FC should be between 4 and 6. I tend to run slightly higher chlorine levels as there are always 4-6 sweaty teens playing water-polo in the pool and we never have the "chlorine smell" !
    Terry in NC
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
