Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Going CLOUDY!! HELP!!
    May 2011
    Abilene, KS
    67
    This same thing happened to me last year and the pool store ripped me for a mint!! My pool started looking a tad cloudy on Monday, no today (Wednesday) its so cloudy you can't see the main drain. FC - 4.2 TC - 4.3 PH - 7.5 Alk - 110 (pool store values concurred). What is the deal??? Please Help!! My son's Birthday/swim party is right around the corner!!!!
    25,000 gallon Vinyl Lined Inground. One skimmer, 2 returns. Pentair WhisperFlo WFDS-4, Hayward Pro Grid DE 3620 with VariFlow valve, LaarsLite 2 propane heater
    Re: Going CLOUDY!! HELP!!
    do you have a full test kit for measuring your FC, and CC and also the CYA? The TC seems funny by being higher than the FC number...
    let us know what you have available to test with... Pool store is less than ideal but better than nothing.... I recommend the kits from TFT mentioned in my signature
    what source are you using for chlorine? Add your pool specs to your signature such as mine so everyone knows what your working with
    Thanks
    Dan
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    Aug 2010
    Dallas, TX
    4,052
    That's correct actually, TC=FC+CC
    What have you put into the pool recently?
    May 2011
    Abilene, KS
    67
    I do have a full test kit...I have the Taylor K-2006 and the Color Q Pro 7. I didn't have all the figures written down and with me. I use 3" chlorine tabs in the feeder and lithium shock.
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    You're probably at the beginnings of an algae outbreak. Time to hit the bleach! In the mean time, post a full set of results and everyone here will have you sparkly in no time!!! (Btw, TC = FC + CC, so TC may in fact be higher than FC if you have CC)
    FC
    CC
    pH
    TA
    CH
    CYA
    Good luck!!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Aug 2010
    Dallas, TX
    4,052
    I can tell you right now the pool is ripping you one for the lithium shock. That stuff is expensive, and not necessary. We need the CYA numbers, and as many other accurate numbers as you can provide. Those tablets will raise your CYA, and it's possible your FC has fallen below where it needs to be for your CYA level and allowed algae to grow. The best advice I can give for now is to perform an overnight chlorine loss test as outlined in Pool School.
    pool-school/overnight_fc_test
    That will tell us if you have organics in the pool.
    May 2011
    Abilene, KS
    67
    I will try to post full slate of test results this evening. I'm very sure the CYA is going to be high....
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Make sure you're running your pump/filter 24/7 for now. That will help while clearing the water. I concur with the lithium shock statement - LOTS of money when bleach (liquid chlorine) or cal-hypo will do. The pool can clear in time for son's party. Stick with the bleach BUT MAKE SURE THE PUCKS ARE OUT OF THE CHLORINATOR before adding the bleach to the pool.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    May 2011
    Abilene, KS
    67
    My filter runs 24/7 anyhow...pool store and previous owner told me it needed to be....Ok on the pucks getting out of the chlorinator. Thanks to everyone!! I truly appreciate it!
    Aug 2010
    Dallas, TX
    4,052
    Pick up a bunch of bleach on your way home unless you are close to a store to get it after testing. Even if you don't use it to shock, you'll use it for chlorinating if your CYA is high.
    May 2011
    Abilene, KS
    67
    Actually own a grocery store...how much bleach? Like several cases or gallons??
    Aug 2010
    Dallas, TX
    4,052
    Hard to say without knowing CYA level. If your CYA is 100, you'll need around 10-12 gallons to get to shock level. The store brand stuff will work, just read the label and make sure it's 6% and not something around 3%. If you end up needing to shock, this'll get you there, and give you time to go get more bleach (you'll need it by morning). If this is the case and you DO need to shock, be sure and read up on the shock process in Pool School. This is all speculation, we will know more when you have your full, accurate, test numbers.
    30,426
    Hold on the bleach and the OCLT. Test your water first so we know what to suggest.
    The OCLT is not needed yet because your water is so cloudy....we are almost SURE something is brewing.
    Secondly, no need to put the chlorine in if you are going to have to drain 50% of your pool water to get the CYA manageable.
    Aug 2010
    Dallas, TX
    4,052
    Ah very true
    Sorry, I'm very used to picking up chlorine on my way home.
    May 2011
    Abilene, KS
    67
    Ok. Here's the test results as of 15 minutes ago...it is really burning through chlorine!
    FC: .74
    TC: 1.24
    PH: 7.3
    TA: 114
    CH: 176
    CYA: 90
    May 2011
    Abilene, KS
    67
    FYI...I do have plenty of algaecide on hand that the ps suckered me in to before I found this site if I need to use it...
    Aug 2010
    Dallas, TX
    4,052
    Don't use the algaecide.
    So your CYA is 90. Now you have to decide if you want to work with that level or drain some water as Dave stated. A number around 40 would be far more manageable to shock with, but that's going to require replacing over half your water.
    Do you not have the FAS test for chlorine? You really need it for the shock process. This is the one where you add DPD powder, then add drops until the pink changes to clear.
    May 2011
    Abilene, KS
    67
    I think I have it on the Taylor kit but I am Mott good at comparing the colors...I will try!
    May 2011
    Abilene, KS
    67
    My other kit is a Taylor K-2005 not 2006
  20. Back To Top    #20
    May 2011
    Abilene, KS
    67
    I do not have a kit that performs the FAS test...
