Thread: Cover will not close
    I have a Infinity 4000 pool cover that sometimes does not want to close. There is a
    magnetic pickup on the end where the cover pit is that stops the cover when it is fully
    open. Does anyone know the setting or gap amount to adjust this switch to. I think
    the cover may be opening to far and when I go to close it, it sees the pickup and shuts
    off the motor.
    18 X 40, Ig vinyl, 3/4 HP Sta-Rite Pump, Sta-rite System 3 Cartridge Filter, Sta-rite Gas Heater,
    Autopilot Ditigal SWG, Legend Pressure Side Pool Cleaner w/booster pump, TF100 Tester
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Cover will not close
    Sorry, can't help...
    Mar 2011
    441
    Quote Originally Posted by fklarrison
    off the motor.
    Typically this pickup will only prevent the motor from opening the cover further, not closing.
    20X40 30,000 gallon gunite pool
