Thread: Brushing
    Brushing
    My pool is crystal clear with the following numbers being typical
    fc = 7-9
    cya= 70
    ta = 100
    ch = 350
    ph = 7.6
    How often should I brush the sides....also is brushing the bottom required or is the vacuum sufficient?
    thanks
    6600 gal IG concrete/gemcoat
    Fresh water
    1 HP motor
    StayRite PLM 100 system 2 filter
    full sun
    Treasure coast, Florida
    Aug 2010
    Dallas, TX
    4,052
    Re: Brushing
    Before I got my robot, I brushed the pool every day. Now I brush it... never.
    Do you have a salt pool?
    Re: Brushing
    The standard is to brush the entire pool once a week, or use a pool cleaner that does the same thing for you. Vacuuming is essentially the same thing, so that counts as long as you are vacuuming/brushing everywhere.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Re: Brushing
    Does a Polaris or similar sufficiently go everywhere to count as brushing?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Re: Brushing
    Yes, a Polaris counts.
