Results 1 to 9 of 9
Thread: Thanks City of Houston
    So, if you call before you put in a pool and request a new water meter, have it installed by a city approved contractor, have it inspected and pay for a permit, the City will not charge you for sewage.
    I did not
    Current Charges
    WATER CHARGE 308.29
    SEWER CHARGE 316.58
    Total Amount Due
    624.87
    15000 Salt Water, Hydrazzo plaster, all Jandy equipment. SWG, Polaris 280, booster pump, raised spa
    Houston, Texas -- It's a 105 in the shade.
    22,553
    Re: Thanks City of Houston
    Did you request a waiver of the sewer charge because you were filling a pool? Some places (and people) will allow you to do that one time even without a separate meter.
    I wouldn't complain to much. I bet it'd cost more than $300 to install a new meter and get a permit so you may be better off the way it is.
    Aug 2010
    Dallas, TX
    4,052
    If you have an irrigation system, it is worth it. I save a ton on my bills because there's no sewer charge for my water used for the pool and irrigation. It isn't uncommon for me to use 25,000 gallons on the yard and pool, last year when I had a pool leak and was watering 3 days a week I could use 45,000 gallons and my water bill was only around $200.
    Jun 2007
    Houston, TX
    11
    We're in Houston...we got a letter from the city last summer that they had discontinued the break on your bill for filling a pool. I don't know how the new meter would come into play though...does it actually separate out water from sewer?
    Cliff
    16x26 AGP
    Jacuzzi DE Filter
    1HP 2-SP Hayward
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    This is exactly why I put in a separate "irrigation" meter. They just finished installing it this week. $140 bucks and for what they had to do to get it put in it was a steal. They had to bore across the street, and hand dig the trenching b/c the gas line was very close to where they sited the new meter to be. 6 guys all day long, plus a bunch of equipment.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Good news for me, pool builder is having to drain the pool to polish the surface!
    22,553
    So, are you having the irrigation meter put in before you have to refill it?
    Did not have a chance to do it.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by AggieTexan
    It is all the same water, just one meter doesn't get billed for sewer. It can make a drastic difference if you use a lot of water.
