Thread: intex swg
    intex swg
    I have a new intex swg, i removed the copper electrodes from it, it does not seem to put out much chlorine, the little metal plates you can see that i guess makes the chlorine one is covered in white and one is not do ya think one is not working? i know you have to clean them but was wondering why one is covered and one is not. I have it running 12 hours and it barely keeps my free chlorine at around 2, i can go all 12 hours nobody swimming and it might raise it 1 part
    free 2.7
    total 3.0
    ph 7.6
    cya 60
    24K gallons, IG, Kidney shaped, DE filter, 1.5HP pump, plaster/gunite, built in 1992.
    Re: intex swg
    The plates have different polarities. Only one of the polarities tends to attract calcium scale. The cell needs to be cleaned. In the future, you should be able to adjust your PH, TA, and CH levels to greatly reduce the amount of scaling you get on the SWG. Raising the CYA level a little, to around 70 to 80, will also help reduce the rate of scaling by reducing the amount of time you need to run the SWG.
    Re: intex swg
    what should i clean with that would work best? the manual says white vinegar but it don't seem to get all the scale off. the pool is 12000 gallons forgot that part. my cal hard is 150 and alk is 90 what should they be to keep this to a minimum? I thought i was in the parameters of what it says in the manual. would adding borates help any on the scaling, been thinking of doing that. Thanks for the quick response
    Re: intex swg
    Yes, adding borates will help. TA at 90 is fairly good, but you can bring that down to around 60 or 70, which will help.
    You can use a dilute muriatic acid mixture to clean the cell instead of vinegar. Mix one part of acid into four parts of water and clean the cell with that.
    Re: intex swg
    thanks for the advise, I' ve saved enough money reading topics on this forum in the last 2 weeks that I paid for the lifetime sponser so I didn't feel guilty Best money I ever spent
