Thread: Handrail position center or offset?
    One of the options I chose for my pool is a handrail for the 8 foot 4 steps in the shallow end. This handrail can be best described as what Snoopy's profile looks like. My neighbor positioned his to the side of the steps and my PB insists that centering the handrail is the way to go (i.e. the point of the hand rail is to be able to use it in the middle). I see both my neigher and my PB point on this issue, but wanted to hear what others have done or would do. My reasoning for wanting it on the side is that the kids like to sit on the steps and kick their legs and make splashes. With the handrail in the center it makes for more of an obstacle. On the side it still allows wanting to use the handrail a means to do so.
    FYI I am pretty sure this is the kind of handrail where the two posts mount on my concrete pad outside of the pool and the lower bar is straight and not the longer hand rail I have also seen where it dips down almost into the water but both pegs are still set in the concrete.
    My pool dig started today. They got the entire earth moved and steel walls up in less than a full days work so I am more than happy at the moment!
    PB scheduled for June 2011...
    18 x 36 Steel Wall Vinyl 23K gallon (8 foot hopper), Hayward 4820 DE Filter, Hayward 1HP Super Pump, Hayward 250K BTU NG heater.
    Western Pennsylvania
    Re: Handrail position center or offset?
    I prefer center mounted hand rails for wide steps and side mounted handrails for narrower steps. Center mount requires wide steps so there is enough room for a reasonably large person on either side of the rail.
    what about either doing 1 rail in the center, or one on each side..?
    PICS!!?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jun 2011
    Cottleville, Mo.
    1
    I decided to put mine on the side. That way it is out of the way but still there to use.
    Aug 2010
    MA
    173
    I chose not to have one installed at all.
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Sep 2009
    Greentown, IN
    914
    I think I would tend to lean towards putting it to the side. Not everyone who uses the steps is going to reach for the handrail and if you have a lot of kids around they do tend to like the steps.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
