Thread: Simple worksheet I created to record my test results
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Attached is a simple worksheet I created to record my test results. It has the directions for each test, desired ranges, and min/max levels. I then enter all results into an Excel spreadsheet so that I have a running log. Feel free to edit as needed. Enjoy!
    Attached Files Attached Files
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    Re: Simple worksheet I created to record my test results
    Nicely done. I think some of the min/max ranges might be adjusted based upon BBB learnings, as well as whether you have a SW pool, vinyl, concrete, etc.
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    Apr 2011
    Somewhere on the Emerald Coast
    156
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Cool, Ive pondered building one myself. Thanks for sharing these.
    Essential Links:
