Thread: sand filter leaking
    sand filter leaking
    can any one please tell me why my sandfilter is draining when I have it sat on filter? it is draining like it is sat on backwash. thank you
    Re: sand filter leaking
    Welcome to TFP!
    If water is coming out of the backwash port when the valve is set to filter, there is something wrong with your main valve. On a multi-port valve the most likely problem is the spider gasket. On a push pull valve the problem would usually be an o-ring inside the valve.
    thank you for such a quick reply
    Jul 2008
    McDonough, GA
    97
    Or you could be like me and put the handle on backwards when I replaced the spider gasket
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
    that would be something I would for sure prove. LOL
