Thread: Swamp again
    Swamp again
    Almost had my pool clear and now it is dark green again. We had to go out of town for 2 days so I missed one day of testing. We came home and the pool was slightly green. I brought it up to shock level that evening and have been maintaining shock levels for 3 days now and it only seems to be getting worse. Out of frustration I did dump a bottle of algicide in a couple of days ago. Could this have made things worse? The green did seem to get much worse after that. We have had some storms and now the temps are around 70 degrees outside. All last summer I battled algea and foresee this summer being the same. I did change out the sand last August. I saw much faster results a couple of weeks ago when I first started on the pool. This is so aggravating!
    Thanks for any advice.
    FC-15
    CC .5
    PH 7.8
    TA-180
    CYA 30
    17K gal, AG, Hayward Sandfilter, new to the BBB method.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Swamp again
    How often are you checking the chlorine? It can drop pretty quickly, even in an hour or so. If you are seeing it drop much between tests, you may need to check it more often.
    30,432
    Re: Swamp again
    read How to "Shock your Pool" up in Pool School. Then, shock the pool according to that Process. Follow it completely and carefully until your pool is clear.
    Re: Swamp again
    I have been checking it every 2 hours and adding bleach every 2 hours today and yesterday. The FC loss last night was only 2 but it is still the same color.
    Re: Swamp again
    How has your filter been behaving? Has the pressure been going up? Have you needed to backwash recently?
    SW Indiana
    9,199
    Re: Swamp again
    Sometimes it will look worse at the beginning. Be watching for a shift from green to a grey-blue tint.
