Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: My Intex 16x48 with custom deck and stairs
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Here's some build pics of our intex pool we put up at the end of last season. We're very happy with the results and are getting a lot of good use out of the pool.
    Leveling out the ground
    We ended up using a very thick pond liner under the pool. It's under the blue tarp. It was very expensive, but it will keep grass or weeds from growing through the liner. We learned this the hard way very early on even though I was very careful to kill everything under the pool.
    Initial posts for deck
    Beginning the framing
    Custom made stringers. I made an excel spreadsheet that makes measuring and cutting stringers extremely simple if anyone is interested.
    Started decking surface
    Ready for spindles
    Meshing the decking planks
    View from the top
    Completed!
    The stairs that are in the pool are great. I think they were only $200 or something and are perfect. So much nicer getting in and out of the pool than ladders.
    I'll post some new pics. New features include better landscaping, wiring at the pumps, and stained the wood. Also replaced the intex rope that holds the legs in place with a nice 1" nylon strap in gray. Next is pcv plumbing to get rid of the hoses and have some valves that will make maintaining the SWG system much easier.
    Intex 16x48 Ultra Frame.
    (B Size) pump
    Saltwater System
    Custom Deck
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: My Intex 16x48 with custom deck and stairs
    Looking good!! Make sure you post some pics of the plumbing.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Jun 2011
    Longview, TX
    11
    Flippin Sweet...how long will the Intex pools last? Im looking at getting one.
    Doughboy 24ft AG
    1.5 HP pump, Sand Filter
    15,000 gallons
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Good question. For a long time I hope. The ultra frames (recommended) look like they will last a very long time. I've already had to set up this pool 3 times due to mistakes made by me. and everything is holding up great so far.
    Setup Pool #1
    - Weeds started to grow through liner. Bought tougher liner to put under pool so took down pool
    Setup Pool #2
    - Used for the rest of the season, but rope deteriorated (it's not great quality) and legs started to bow out slightly. So took down pool for the winter. Bought a nice 1 inch wide 70 foot long nylon strap and ratchet to use in place of the shoddy rope.
    Setup Pool #3
    - Now have strap in place. Legs are now nice and vertical. Just slight unevenness problems, but our yard has a decent grade down towards the back so that considered it's not really that bad. Hopefully the last time we need to set up the pool
    (B Size) pump
    Saltwater System
    Custom Deck
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    It looks awesome! If you don't me asking, about how did the deck cost?
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Total cost in materials was about $350
    (B Size) pump
    Saltwater System
    Custom Deck
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Quote Originally Posted by Rªzª
    Did that include the ladder too? Oh and what kind of material did you use for the top of the deck (like the floor of the deck) is it some type of like water resistant board or something? Sorry for so many questions, I've been looking for some pictures of a simple deck on an intex pool and your's is exactly what I had in mind.
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Quote Originally Posted by carterj92
    Ah no yeah that did not include the stairs. They were around $200. Very happy with those. For the decking surface, I used that synthetic decking material at home depot. It's expensive but it will last forever and completely waterproof.
    (B Size) pump
    Saltwater System
    Custom Deck
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    [quote=Rªzª]
    Quote Originally Posted by "Rªzª":204s0w7u
    Ah no yeah that did not include the stairs. They were around $200. Very happy with those. For the decking surface, I used that synthetic decking material at home depot. It's expensive but it will last forever and completely waterproof.[/quote:204s0w7u]
    Thanks so much! I think I might do something similar than.
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Here's the plumbing I did on my pool. Having the valves right there makes it much easier to clean the filters or the plates in the saltwater system
    (B Size) pump
    Saltwater System
    Custom Deck
    how much did building the deck cost for you?
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    counting the stairs that go in the pool the total was around $550. The deck itself was about $350 for all materials
    (B Size) pump
    Saltwater System
    Custom Deck
    May 2011
    East Texas
    11
    It looks to me like some of your wood is not pressure treated, is that true?
    Yukon Jack's Avatar
    May 2011
    Rose Hill, KS
    94
    Very nice setup!
    18x33 AGP, 17,300 gal, Hayward Sand Filter, 1.5 HP 2 Speed Hayward Pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Unless my eyes are going, that all looks like PT to me, except the deck surface. PT is a lot lighter these days, than the spruce green we were to used to back in the day
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Yeah it was all pressure treated. All had a slight green texture to it when we first bought it. Was starting to all turn grey so we weatherproofed/stained it about a month ago. Can see the cedar flavor to it in the newer pics
    (B Size) pump
    Saltwater System
    Custom Deck
    Hi just wondering about the deck did you have plans on how to build it? If so where can we find those?
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    I just made up the plans myself. Sort of a custom fit sort of thing. I think you can get the gist of the design from the pics, but if you like I can scan in some of my initial drawings.
    (B Size) pump
    Saltwater System
    Custom Deck
    Rªzª's Avatar
    Jun 2011
    Orlando, FL
    26
    Here's calculator I made to cut out the stringers for my deck stairs. With this making stringers is very straight forward:
    http://razaland.com/stringer/
    (B Size) pump
    Saltwater System
    Custom Deck
  20. Back To Top    #20
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    looking good!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
