Thread: FC high and climbing
    Folks,
    I am running my pump on high 24/7 right now for aeration (reducing TA for borates). My TA has hit my target value of 70 and I have demonstrated the ability to raise PH by 0.5 in 24 hours with my homemade aerator. Here is my problem, I have a SWCG and it is cranking out chlorine! Latest test results:
    TC: 13 (was 11.5, SWCG set to 45%)
    CC: 0
    PH: 7.0 (added MA tonight)
    TA: 70
    CH: 20
    CYA: 40
    Salt: 3500 panel
    There has been no bather load whatsoever and the pool is clean. Should I simply shut off my SWCG for the time being? If so, how?
    TIA
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
    Re: FC high and climbing
    Okay ... I think I just had a duh moment .... reduced cell to 15% for tonight. I will recheck in the AM. No swimmers, no sun, and it has been cold ... all equals no FC usage ...
    Feb 2008
    Denton, TX
    5,061
    You might even shut the cell off for a while and let the FC come down on its own.
    Tested this AM. Aeration is working but FC still rising. I am going to turn off the cell for today.
    TC: 15 (was 13 SWCG set to 15%)
    CC: 0
    PH: 7.2
