Results 1 to 16 of 16
Thread: Is this a sign of trouble?
    Aug 2010
    Lake Jackson, TX
    130
    I've noticed small black spots forming on the walls of my pool. Brushing doesn't seem to affect them. Scraping with a fingernail breakes them up some but them seem to be embedded into the plaster some. Any thoughts what they might be?
    The water has been clear and the chlorine has been maintained for several weeks now.
    FC 10 (CYA ~80 LAST CHECK)
    CC 0
    pH 7.6
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Is this a sign of trouble?
    Possibly black algae. BA are usually round, black spots. If you remove one and smear it on a white paper, it would appear green (if it is black algae). I think waste/Ted said to smear it on the back of a white business card.
    What are your other test results?
    Also, has the pool been let go for a while, allowing FC to drop?
    Do you have pics?
    You're done SLAMing when:
    Aug 2010
    Lake Jackson, TX
    130
    I haven't tested everything lately but last I checked ~early May
    CYA 80
    CH 410
    TA 190
    TEMP 88 F
    I have added water 4 or 5 times since opening, usually an inch at a time. The pH has gone up aas high as 8 about 2 weeks ago and I added MA to lower. I have also added MA twice and aerated to try and lower TA. The CC has been steady at 0 with one test o month or so back showing a trace. Other than that the FC has dipped low (4) a couple of times since opening, last one 3 weeks ago.
    Thanks.
    Feb 2008
    Denton, TX
    5,061
    You may need to start the shocking and brushing process for black algae. It is tenacious but can be eradicated.
    Having a good test kit will help you immensely. You need to be able to accurately test for FC, CC, CYA, TA, pH, and CH. Foolow the link in my sig line to get a TF-100 test kit if you haven't ordered one already.
    Aug 2010
    Lake Jackson, TX
    130
    I have a Taylor kit. I rechecked all my numbers last night and they agreed with the previous post.
    How long do I need to shock for black algae? Is it the same basic process for "regular" algae?
    What does black algae look like? My spots are smooth and flat, pretty much even with the plaster surface. I found a pic online that showed globules sort of like a mushroom. I took some under water pics yesterday if the come out ok I'll post as soon as I can.
    Thanks.
    Getting rid of black algae is a project. Lets hope you don't actually have black algae. One good check for black algae is that it won't really all brush off and yet you can get some of it off. Also, if you scrape some off with a finger nail and smear that on a piece of paper it will look green, while on the pool it tends to look black.
    If it is black algae, you can try rubbing it off with a trichlor tablet.
    Aug 2010
    Lake Jackson, TX
    130
    Here are some pictures of the spots. Hopefully they are clear enough. I brushed with a stainless steel brush without much effect. I also tried to get a piece to put on white paper to see if it was green but no luck. Most of the spots are too small to get hold of. A couple of them were big enough to break open and it did seem to be green behing with fine hairy looking roots. So, what's the verdict? Black algae or not?
    Thanks.
    Aug 2010
    Lake Jackson, TX
    130
    more pics...
    Aug 2010
    Lake Jackson, TX
    130
    one more
    Aug 2010
    Lake Jackson, TX
    130
    one more
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Looks like black algae to my unprofessional eye. 302 and 301 also look like some caalcium scale, for what it's worth.
    Off to the pool store with you - time to buy an algae brush! It fits in your pole like a normal attachment, but it's a small -maybe 6" wide, coarse, stainless steel brush.
    Aug 2010
    Lake Jackson, TX
    130
    I got the stainless brush today and brushed once so far. It didn't seem to faze it much but I'll keep trying. I'm going to raise my base FC level until this is cleared. Do I need to shock for this? My cc levels have been 0 for at least a couple of weeks.
    Thanks for the input on the calcium scale, I didn't know I had that too. Not surprised though since my CH has been high since I acquired the pool. How do you fix that problem?
    Does lowering the pH help to fight the BA?
    Richard320's Avatar
    Jan 2010
    19,034
    The search function is your friend.
    Type in "black algae" just like that, with the quotation marks. You'll get a lot of hits. Look for the threads with lots of replies.
    I'm no expert, especially not with this problem.
    Lowering PH helps prevent calcium scaling, but won't have any effect on black algae.
    I have a suggestion. Try rubbing one of the spots with a trichlor tablet for a minute, and holding a vitamin C tablet against another one for 30 seconds, and see if either one changes in appearance.
    Aug 2010
    Lake Jackson, TX
    130
    I tried the vitamin c and trichlor tab experiment over the weekend. I did not see any change with the trichlor tab. The spot did fade with the vitamin c. I'm going to do it again since it was tough to do given the spots are mostly 4-5 feet down and are still fairly small.
    So what does that mean?
    22,551
    If the vitamin C affected it then it means it's most likely iron stains. If there are a bunch of them you may consider an AA treatment but if there's only a few the tablet is a better way to go.
