Results 1 to 17 of 17
Thread: Should pool water be blue?
    fordfampool's Avatar
    Jun 2011
    Wisconsin
    44
    Our pH was a little low today as well as our CYA - so I added a small amount of ph Increaser and CYA (from BioGuard) at about 2:30. Now (7:30) we noticed the pool is still nice and clear, but a blue tinge (we can see it where the water comes up on our steps). Pump has been running all day. We did shock it last night with a product called Bioguard Smart Shock (that you can swim 15 min. after putting it in the water?!) I don't think we'll be using that one again...
    According to a quick dip test the pH is 7.2, FC 4, TA 120, and CYA 30.
    Will do a more thorough test here after dinner.
    Anyway, I noticed a lot of posts with people loving their "clear blue water"...so is pool water supposed to be blue?
    Thanks, all!
    Sarah
    loc: WI ~24k gal vinyl w/fiberglass steps, 18ft x 38ft, 3.5ft shallow(90deg floor to walls)-8ft deep end(floor to 45deg wall to vert wall), 300lb sand filter, chlorine (liquid shock and trichlor). Skim in middle, single main, two returns facing away from skimmer and towards the surface a bit. Sarah and Mike. We are new pool owners - it came with the house!
    Feb 2008
    Denton, TX
    5,061
    Re: Should pool water be blue?
    If a column of water is thick enough, it will be blue to the eye. Notice how pools with white plaster appear blue? Apparently, this is due to the bending of the bonds between hydrogen and oxygen.
    Jun 2011
    Wisconsin
    44
    I thought about that - but it was an obvious change from this afternoon to this evening from very clear to a blue - the amount of water I was looking at was the same. The sky wasn't blue either.
    Strange!
    Hopefully it will clear up by morning. I am starting to see how some of these "helpful" chemicals from the pool store have funny side effects...
    Jun 2011
    Wisconsin
    44
    Our numbers are:
    pH 7.3
    FC 8.5
    CC .5
    TAK -150
    CH 300 (this could be high, we aren't 100% we did the test correct - the pink to blue was so subtle and appeared purple? for a bit)
    CYA 35
    We are still getting used to the test kit, but those should be more accurate than what I posted earlier.
    Hoping for clear water in the AM!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I say yes. My pool walls are white. When I go out back to smoke when it's light but the sun still isn't up, it looks blue. It also looks blue when the light is on and it's dark outside. The color ain't coming from the sky nor the walls...
    Jun 2011
    Wisconsin
    44
    Our water is blue immediately (daylight hours, if it matters). For instance, we have fiberglass steps going into the pool. The water looks blue comparing the two inches above and below the water line. t doesn't seem right to us that it should be that blue.
    - Mike
    p.s. Sarah - post a pic
    Jun 2011
    Wisconsin
    44
    I think it is looking less blue this morning but it's in the shade, hard to tell?! Tried to take a picture but in the shade it doesn't really turn out.
    I am leaving the cover off today hoping to get the FC levels down a bit from 8.5.
    Hopefully, the blue will clear up today as well, or we'll just get used to looking at it blue?! It was really weird though, all of a sudden looking like someone put blue dye in the pool!?!
    Thanks for the responses! I will let you know if it does clear up, or if it is just our eyes that need adjusting.
    Jul 2010
    England, UK
    156
    Are pools blue for the same reason that the sky is blue? The sky is blue because it scatters the blue light (short wavelengths) more than the red (long wavelengths), so more blue light reaches your eyes.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by loop_pea
    We have a winner!
    Both scattering and absorption are involved which is why the water heats up in the sun. Longer wavelengths (red) are absorbed and shorter wavelengths (blue) are mostly scattered.
    Color of water
    Mark
    Donldson's Avatar
    NW Ohio
    2,892
    There are additives that will temporarily turn water a much deeper blue than natural. Is it possible the previous owners used some and it's still there? I only ask because if you are seeing a significant blue tint less than a couple of feet down it probably isn't normal unless the position of the sun is causing the liner to reflect on it.
    Also, I don't think anybody mentioned this yet, but please read the Pool School info on shocking. You cannot properly shock the pool in 15 minutes. I actually found this site because I was trying to shock the wrong way and wasn't getting anywhere.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2011
    Wisconsin
    44
    It think it was caused by an additive. It is looking better already. It is still blue, but not so much contrast one inch down from the waterline.
    Quote Originally Posted by fordfampool
    I suspect possible copper due to the unusual blue of the pool water and the purple in the calcium test. You could have the water tested for copper and iron to see if that's what's causing the blue. Also, check all chemicals added to see if any contain copper.
    Support the site
    Quote Originally Posted by Donldson
    I think they were referencing a non chlorine oxidizing shock such as mps commonly used in spas. My new pool came with a whole box of these packets....
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    Donldson's Avatar
    NW Ohio
    2,892
    Quote Originally Posted by Red Shirt Ensign
    I thought that too, but the only Bioguard Smart Shock I have seen is Dichlor.
    I love my crystal blue water. It sparkles!
    Of course the coating in my pool is called gemcoat, that has blue crystals embedded in it.
    Purty!!!
    6600 gal IG concrete/gemcoat
    Fresh water
    1 HP motor
    StayRite PLM 100 system 2 filter
    full sun
    Treasure coast, Florida
    Jun 2011
    Wisconsin
    44
    Sarah and I saw the blue hue again, but this time we made no large changes. We think it may be due to the time of day/angle of sunlight after all.
    -Mike
    Jun 2015
    Clarkston, MI
    5
    If you used pool salt with the additive yellow prussiate of soda (anti caking) and had any iron in water then that may have dyed your water blue. ...or you have copper that oxidized due to the shock.
