Thread: tear in liner above water line - 12"
    My liner has torn open above the water line. The tear is now 12" and growing... Liner is about 5-7 years old.
    The liner was stretched in this area during install; the liner never seated totally where the bottom meets the wall and you can see the vinyl pattern is more stretched here. The stretching and the sun has made this the area fail first :<
    Should I try to patch it ASAP? or let the tear open up and relieve the tension, partially drain and patch?
    Thanks
    30,421
    Re: tear in liner above water line - 12"
    Amazingly pertinent, look at this post from just a few minutes ago...
    spray-on-duct-tape-and-liner-t23816.html
    Jun 2011
    Dallas, Texas
    3
    after a lot of searching, seems no one carries the spray on duct tape anymore. EPA??
    Bummer.
    Regards
    Mike in Dallas
    20' x 40' IG Vinyl Liner (Heldor: 1989)
    almost ready for 3rd liner
    Mostly copper-silver system since 1991
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by leaky
    Thanks
    Welcome to TFP!!
    I hate to tell you that your liner is failing fast You might get another season or 2 out of it, if you patch it. Advice on applying the patch is here
    Luv& Luk
    -Ted
