Thread: Small waterfall features - extra pump needed?
    Sep 2007
    Madisonville, LA
    83
    I am thinking of having my PB install an extra line for a future pool feature similar to the one below. Can this line be plumbed into the source for the normal returns, or does it need a dedicated booster pump? Can I use the booster pump for the vacuum system?
    Lee
    10200 gal 12x24 IG vinyl, Dual Main Drains, Sta Rite System 3 cartridge filter, 1.5 HP pump, Zodiac LM3 SWCG, Letro Platinum w/booster, Colorlogic, Spraydeck, Deck jets, Oasis 36" Arch Waterfall, custom built BBQ island
    mas985's Avatar
    Pleasanton, CA
    11,742
    It probably doesn't need a separate booster but you want to make sure you have a separate line back to the pad with a valve so that you can control the flow between the returns and feature.
    Mark
    Sep 2007
    Madisonville, LA
    83
    Mark, thanks for the quick reply. I forgot to mention that I will also have four deck jets. My pump will be 1.5hp, so I am hoping I have enough ooomph for everything: 1 skimmer and 2 pool returns.
    Lee
    Oct 2007
    Suwanee, GA
    31
    Make sure you add a valve on the return to the deck jets from the pump. We had just a 3/4 pump on our 4 deck jets and they were shooting over 50 feet in the air. We had to add a valve to restrict some flow. Now we have the ability to adjust the pressure a get different levels with the deck jest.
    25,000 Gal chlorinated rubber painted pool. 175sf Hayward cartridge filter. 1 1/2 hp AO Smith pump.
