Although you have added "lots" of chlorine, I still am not able to see where at any point in your past posts that you have reached shock level even once. Please use the Pool Calculator to determine the amount of chlorine to add to reach 18 ppm, your shock level, and add it all at once. Then, maintain your FC of 18 until you are finished shocking as evidenced by: 1 ppm or less of FC overnight, you have 0.5 ppm or less CC, and your water is clear. You need to add enough FC to get it to and keep it at 18 until finished. You may need to check the FC every 30 minutes in order to keep it there. I'm sorry if I come across as a little bit direct, but unless you do exactly this, you will be spinning your wheels the entire summer with this algae thing.
