Thread: Can't Seem To Get It Quite Done This Year?
    korinian's Avatar
    Claremore, Oklahoma
    16
    I’ve got a 50,000 gallon IG vinyl pool. 300 lbs Sand Filter. New sand 2 years ago. I’m testing with a TFP Kit.
    I opened the pool to a swamp this year… (mesh cover and lots of snow/rain this winter). I’ve been dumping bleach into the pool daily (3 to 6 1.4 gallon GV bottles) for almost 3 weeks and it has killed everything, but it’s still that white cloudy color. I have a 10’ deep end and can’t see the drain.
    I’ve been doing the bleach method for a few years now. Usually, I get crystal clear water within a week. My numbers seem fine and I’m not losing much chlorine daily (about 1 to 2). I’ve had my FC at 10+ for days and days. I’m just wondering if I’m missing something obvious to everyone but me. My pump has been running 24/7 for 3 weeks now. All the debris is out of the pool and I’ve run the Dolphin to get the last of it in the deep end. I’m Just looking for some insight and I'm tired of buying bulk bleach. Thanks.
    Numbers as of this morning:
    FC = 12
    CC = 0
    pH = 7.5
    TA = 60
    CYA = 30
    Thanks.
    50,000 gallon vinyl IG, Hayward 1.5hp Pump, 300lbs Sand Filter located in Oklahoma.
    - Korinian
    Sep 2009
    Greentown, IN
    914
    Re: Can't Seem To Get It Quite Done This Year?
    Have you brought your pool up to shock level and done an overnight FC test?
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    korinian's Avatar
    Claremore, Oklahoma
    16
    Yes. An example is last night. At 8:00pm 14 and at 6:00am 12. But that kind of swing is pretty normal for my pool. I usually add 1 jug of bleach (1.4 gallons) each morning during the season.
    - Korinian
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by korinian
    If you are loosing chlorine at night, it should mean you still have organics in the pool and you are not done shocking. Advice I have seen on here is lots of brushing and looking for any crevices where you might have things hiding.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
