Results 1 to 7 of 7
Thread: Eye ball sizes and aiming
    May 2011
    Los Angeles, CA
    228
    Hello all!
    Being new here, can you please tell me how to aim the eye balls? I have three returns to my pool. First at deep end, second near the steps and third at the shallow end. The shallow end return gets the least amount of water as it is further away from the pump.
    I know the water should do circles in the pool. But:
    1) should the eye balls point up or down? I run the pump at very low speed for just enough flow rate to do the required change over per day. Id like the surface to be moving as i have trees all around and there is a constant shower of leaf and debris.
    2) should I install a smaller eye ball at the shallow side return to speed up the water there?
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    May 2011
    Los Angeles, CA
    228
    Re: Eye ball sizes and aiming
    Here is a diagram of the pool[attachment=0:32471dw4]pool.pdf[/attachment:32471dw4]
    Attached Files Attached Files
    Mar 2007
    Coastalish 'down easter'
    4,160
    Close, but no cigar Thanks for the pic
    What you want to do is put the 1/4" eyeball in the deep end return to build up back pressure to the other 2 returns. You may want to put a 1/2" on the steps to really force more pressure to the shallow end return.
    As for aiming, start with having the deep and shallow returns point straight out, parallel to the surface. The stair return should have been on the right side of the steps, but there's nothing to be done about that now , point that one slightly up and towards the corner of the spa, to help keep debris from collecting in the stair area.
    HTH
    Luv& Luk
    -Ted
    May 2011
    Los Angeles, CA
    228
    Thanks!
    May 2011
    Los Angeles, CA
    228
    ummm any ideas how to loosen these eyeballs? I can remove two but the third one ( on the steps) wont budge!
    Feb 2008
    Denton, TX
    5,061
    I have had to employ the use of Vise Grip pliers to remove a couple of my own. Do so very gently, just enough to get a good grip as you don't want to crack the fitting.
    May 2011
    Los Angeles, CA
    228
    Thanks!
    Just brought 1 each of 1/2", 3/4" and 3/8" eyeballs on ebay....
