Thread: Replacement multiport
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    While I'm waiting for some parts for my multiport I'm debating (since they may at this point tell me they really don't have it in stock) replacing the whole multiport valve. Does the replacement have to be the exact OEM-sourced equipment or are generic/compatible replacements available? If so how to match up? Thanks!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    30,414
    Re: Replacement multiport
    If I understand your question correctly, all you need to replace the entire multiport is compatible openings.
    If you have 1.5" going in and out of the existing one, then you have to get the same size openings for the new one. You may have to work the PVC a little but that's not too difficult.
    Is that what you were asking?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I need to make sure the valve fits the tank and that openings for the six bolts used to secure it are sized/spaced properly.
    It looks like many valves are now secured by a large ring clamp with a single bolt/nut.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Or maybe I could just look around a little more and find one of these - duh!
    aqua-man.com
    Inyopools.com
    poolandspastuff.com
    These don't look exactly like mine but there's enough information to confirm DV7 valve dimensions and fit.
    I think things in general are manufactured to more skimpy standards then they were years ago. Mine has raised letters for all the markings and on these there are stickers which I read fade and peel over time. Still, good to know there are these options!
