Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Klean Strip Green Muriatic Acid
    I just wanted to verify that the Klean Strip Green Muriatic Acid sold by Home Depot is 31.45% concentration. Does anyone know?
    http://www.homedepot.com/h_d1/N-5yc1v/R ... key=Search
    20K gal, 34'x 17' ovalish IG plaster; spillover spa 7' dia. round; waterslide & waterfall; built 2004; bought 2008
    Pumps: 2 HP-pool & spa; 1.5 HP-slide & waterfall; C3025 cartridge filter; Navigator w/dedicated line; heater; all Hayward brand
    Nov 2010
    Calera, Al
    271
    Re: Klean Strip Green Muriatic Acid
    It is not the same as the MA I get at home depot. And in it's description it says something about not being like "regular" MA. This is the MA I get. http://www.homedepot.com/buy/smart/case ... 97393.html
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    They list it as <25% muriatic acid. Presumably the acid concentration varies somewhat from batch to batch. Assuming it is 22% is probably close enough.
    I checked that link and it is not sold at any Home Depot in a 50 mile radius for me. Where else can I buy the 31% concentration of Muriatic Acid?
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I get it at Lowes.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Got a link? I can't find it on Lowes either.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Yeah that's the same one Home Depot sells but apparently its not 31% concentration.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    It's 31.45%
    When I follow the Lowes link, I see Crown Gallon Muriatic Acid, which is 31.45%, and Kem-Tec which is 29%.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Yes, Crown Gallon Muriatic Acid is the one I use and was referring too.
    Neither of those are available in my area. Any other suggestions?
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    An ACE hardware store would probably have it.
    Tried that also but no luck. Probably has to do with New York state. Any other ideas or should I try buying online?
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Local pool store or someplace that sells tile supplies?
    Not here. Here is a pH decrease powder, not sure how to do the math though.
    http://store.namcopoolstore.com/web63258.html
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    That's a dry acid. Pool calculator tells you how much to add to drop your pH knowing your current level.
    Paint stores often carry muriatic acid. It is used to clean concrete before painting.
    I found the 31% Muriatic Acid at Leslie's. Thanks everyone!
  20. Back To Top    #20
    Mar 2008
    Wake Forest, NC
    128
    Crown Muratic Acid Next???
    Sorry to bring this old thread back!!! I could not get my normal MA from Tractor Supply. So I sent my kid to Lowes and he came back with Crown Muratic Acid Next.... Don't care about strength... Simply want to make sure before I open that it is SAFE to use in the pool... As in is it only Muratic acid? The lowes spec information says not safe for Salt pools which is why I ask.....
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
