Thread: cleer green looking water
    Had a lot of ash in pool after fires in San Diego . Cleaned all debris from pool,filtered for 2 days now pool looks green. Have high chlorine levels(5ppm)and ph is around 7.5 any ideas to get pool back to blue
    Bosqueboy in Virginia
    In-ground 20,000 gal vinyl Grecian, Hayward Star-Clear Plus C1200 cartridge filter, Hayward 3/4 HP Superpump, AquaRite salt water chlorine generator, Heat Siphon C575HP heat pump and Blue Diamond robotic cleaner.
    30,419
    Sandjam,
    Green normally means algae. There are some circumstances where a green tint occurs but it is a temporary condition and usually only lasts a few hours ( I think).
    What is your CYA level? Is it possibly high enough to render your chlorine ineffective? That could result in algae and is my best guess as to your condition.
    BTW, welcome to the forum. You'll get plenty of responses here and your green issue will be sorted out pretty quickly.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: cleer green looking water
    Quote Originally Posted by sandjam
    5ppm is not a high chlorine level. Pool stores will lead you to believe that, but for many CYA levels it is too low, which is what Duraleigh is suspecting. If you suspect anything is wrong with the water, you should have your chlorine around 15ppm, or 25ppm for a gunite pool.
    If you can get a full set of test numbers it would help us give you better advice. Owning a good quality test kit is the best approach, and well worth it, but pool store test numbers will be enough for us to have a much better idea what is going on.
    gonefishin's Avatar
    Joliet, Il.
    413
    Hi there...welcome to the forum
    Like the others have mentioned, a full set of numbers would be helpful. Include Tc, FC, Ph, TA, CYA, metals others (read the stickies in my signature). If it's green, most times it will be algae! Getting a full set of numbers and treating with a chlorine (such as bleach) will clean up most green pools.
    I hope all is ok with you and your family/friends,
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
