Results 1 to 19 of 19
Thread: avoiding algae while away on vacation
    newnan ,GA
    11
    I wanna know any steps or precautions recommended to prevent pool trouble while away ! In the past i have gotten a house/pool sitter while away just to come back to both looking much worse than if i left them unattended ! i will be gone this time 7 days from july 1-8 my water is balanced w cya of 60 ! Should i buy one of those floating chlorinators for the week ??? pool pump/filter is on a timer and runs from 6:00 am til 7:00 pm daily ! any help,suggestions,or guidance welcome !
    24 ft round doughboy with deep end. Hayward pro series high-rate sand filtration system with a 1.5 hp hayward power-flo matrix pump.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: avoiding algae while away on vacation
    Welcome to TFP!
    With your CYA at the current level I would not use any chlorine pucks. You don't want to raise your CYA.
    My suggestion would be to raise your chlorine level to shock level for your CYA, or maybe a little higher, and then cover the pool. The cover will allow the chlorine to linger around longer and not burn off from the sun.
    Hope this helps.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    newnan ,GA
    11
    i was wondering if it would be ok to cover it with the warm water !!! should i try and let the pump circulate each day or no ???
    newnan ,GA
    11
    Also i have to keep my cya up because it's in full sun all day and i have 2 daughters that keep company in the pool daily so bather load is high !!! we really get the use out of it !!!
    It is my understanding that your cya is not going to be depleted once it is in there. You don't need to keep adding more of that. Just keep your chlorine high to prevent the algae outbreaks.
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    Sep 2009
    Greentown, IN
    914
    If your CH isn't too high, I believe there are some tabs you can use that have that in them instead of CYA. Might be another option.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    newnan ,GA
    11
    I know i don't wanna get my cya too high but it is gradually depleted from adding water because of evaporation and the occasional backwash ! I have to add water atleast once a week because of evaporation. i only use bleach for my chlorine and 2lbs of bioguard burn out each week to shock it ! the pool cover sounds like a good idea but should i program the pump to run at all ? Or will it be ok covered for 1 week if i sting it w shock real good and cover it ???
    22,553
    It might be ok if you bring your pool to shock level and cover it with an opaque cover it may be ok. Is your pump on a timer?
    There's no need in shocking your pool weekly. Is there a reason you're doing that?
    Also, how are you getting your test results?
    SW Georgia
    300
    My pool uses about 3ppm per day which equates to 1 gallon of 10-1/2 percent per day. If I am going to be gone for 7 days I add 7 gallons. I personally would probably add 8 gallons just for insurance.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    newnan ,GA
    11
    this is only my 2nd season on the BBB method i guess the weekly shock thing is a habit after 15 years of it ! along with not knowing any better! i have gotta invest in a good test kit ! i currently use a HTH deluxe kit to check chlorine, ph,and alkalinity! i had the pool store test it recently when getting some algacide ! i'm willing and eager to learn a better way! tell me what i need to know ,and where do you get that 10-1/2 percent @ ???
    SW Georgia
    300
    I get 10-1/2 percent at pinch-a-penny ($4.24/2-1/2gal.) and Ace Hardware ($5.75/2-1/2gal.) I only use Ace when I am not going near a pinch-a-penny.
    22,553
    A good test kit is the first order of business. Order one from tftestkits.
    Next is try to break the old habits. Shocking, adding algaecide, listening to the Pool Store, etc. I know old habits are hard to break but you can do it.
    Once you get that new kit post a set of test results.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    I went to England for 11 days and returned to a clear pool. I was going to use a floater, but didn't. I got everything balanced and clean, dumped in a bunch of chlorine to take it up to about 20, and had it covered with a solar cover. The pump stayed on it's usual timer setting. I set the valves so that the spa wasn't drawing, only filling, at a low rate. With the cover floating on the surface, the skimmer wouldn't get much, so I closed the diverter and got all (95% at least) the water drawing from the main drain. Came home to 3 ppm, which was just at minimum for my CYA. Poured in half a jug, unpacked the dirty clothes, and went to bed!
    newnan ,GA
    11
    to jasonknox, i live in GA also more like west central GA we don't have pinch a penny i never saw 1 around here ! but i called my local ace and asked about the 10 1/2 % and they said they don't stock it but could order so i told him to check on it for me and then when i called back he said they couldn't get it !!! is it a ace brand product ??? thanks
    Jul 2008
    McDonough, GA
    98
    If you come over this way to McDonough, our local Ace carries the HTH brand of 10%, it was on sale during Memorial day, 4 for $10.00.
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
    Butterfly's Avatar
    South Carolina
    10,045
    You have gotten good advice, but remember we do not advocate 'dumping' bleach in your pool.
    The amount of bleach/liquid chlorine to add to your pool is based on your CYA # and what you want to do, like shock or maintain.
    We need to know the water test results so we can give you good info.
    If your CYA is indeed 60, then your shock level is about 24FC.
    You can compare recommended test kits in Pool School,
    but most of us recommend the TF100 (sold by duraleigh, site owner) because it is the best bang for the buck and the service is A-1!
    Here's more info for you: need-help-w-vacation-plan-t31116.html
    You're done SLAMing when:
    SW Georgia
    300
    Quote Originally Posted by stv4icp
    stv4icp
    The Pinch-A-Penny I use is in Dothan Alabama. I live in a really rural area and the only competition for pool supplies is 45 minutes away, so I guess in an area like yours there may be to much competition for them to get into the business of selling pool supplies?
    Mar 2009
    Woods of North Florida
    148
    Our ACE sells chlorine because certain businesses use it, not for the pool specifically. I guess people who clean (pressure wash?) houses fill up big jugs in the back of their pick up trucks with it and take it to job sites. I don't really know what they use it for. Maybe you can call around and see who supplies these types of businesses with their chlorine and buy it from them?
    24' Seaspray Evolution CLX Above Ground Pool (~13600 gallons)
    Pentair Sand Dollar SD60 / 22.5" filter / Maximum Flow Rate 60 GPM
    Pentair Dynamo Pump 1 1/2 HP
    newnan ,GA
    11
    OK I'm leaving in the morning ! i only have a regular pool cover no solar cover ! i'm gonna cover it with this but does the pump have to run what would likely happen if the pump is left off ???the water is crystal clear now !!!
