Thread: Water turned Green
    Water turned Green
    I recently installed a SWG in my pool. The Baquacil was getting far too expensive. I have my salt in the pool a bit high but will be fine as I've been told. But, there was no FC in the pool and was instructed to shock. I diluted two pounds of shock in water and poured directly into the skimmer. Immediately, the water returning to the pool was cloudy and green. I have the SWG shut down at this time but should I keep in runnnig as well? Does anyone have any idea as to what may have caused this condition?
    Re: Water turned Green
    Welcome to TFP!
    If you were using baquacil before, have you gone through a baquacil conversion? There is a whole process required to switch from baquacil, you can read about it here.
