Thread: jandy neverlube
    jandy neverlube
    my spa empties into my pool (slowly) when filter is off....changed 1 check valve and other is good....the culprit seems to be the neverlube (spa drain)...my question is this...can I just adjust the diverter by taking it apart or do I have to replace valve.......not too confident (working on) with this valve
    thanks in advance for any suggestions
    9 year old 15,500 gallon, inground plaster pool in AZ with attached spa
    SWC by SGS, model Breeze 540
    3 separate pumps (filtration, water feature & spa) also has in floor Polaris/Zodiac 5 port leaftrapper system (popups)
    heater (never used for main pool, only for heating spa)
    Re: jandy neverlube
    The Jandy NeverLube valves can be opened up, cleaned out, have parts replaces etc. You almost never need to replace the valve body.
