Thread: Had water tested at pool store for 1st time
    Apr 2010
    Central Illinois
    205
    So I thought I'd bring a water sample to the pool store and get it tested just to compare to my results.....
    My Results
    FC 2.5
    CC 0
    pH 7.5
    TA 70
    CYA 40
    Pool Store Results
    FCL 1.88
    TCL 2.06 (what is this?)
    pH 7.58
    TA 88
    CH 140
    CYA 38
    They everything is OK, except I need to add 4 lbs. of Hardness, I'm not sure if that is right or not? But I know that my FC is too low, their range is 1-3 ppm.....wouldn't people have algae ALL THE TIME if they went with that range?
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    May 2011
    lebanon tn
    370
    Re: Had water tested at pool store for 1st time
    pool stores don't account for the CYA, the just test it...
    the 1-3 ppm FC is for non-stabilized pools, and it works fine; just impossible to maintain FC on a sunny day or even for a short weekend vacation!
    don't worry about adding hardness- not needed in vinyl pools!
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    30,402
    Once you get your FC up in the 3-5ppm range, those are VERY nice numbers, indeed!
    How does your water look?
    Apr 2010
    Central Illinois
    205
    Thanks & the water looks great.
    TF-100
    Quote Originally Posted by oasis1
    Yea... And, if people don't have algae all the time, how are pool stores going to sell you algaecides, phosphate removers and other chemicals to control it... Hmmmmm?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    I'm impressed though...overall those test result are not too far off from your own.
    TCL would be Total chlorine = FC+CC
