Thread: Liner Leak, Assistance Please
    vinyl liner leaking what is the best way to find it?
    22,550
    Re: Liner Leak, Assistance Please
    IS it an inground or above ground pool?
    Does it stop leaking at a certain point?
    above ground and the ground stays wet in 1 place . r.swanson48@yahoo.com
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by r.swanson48
    Carefully check all fittings that go into or out of the pool pump, filter, or heater. Is the wet area near your skimmer/return? Does the pool have a main drain? Otherwise, hop in the pool with some nice big goggles on and inspect the area inside on the floor and pool walls and look for little bubbles. You can also use food coloring to test a suspected leak point.
    pool-school/leak_detection
    ok thank you i will try the food color
