Thread: swg pool filled, about to add salt but pump can't work!!!
    I have a intex swg 16X48, holds just over 5,000gal. It's full of clear water, about to add salt but the air release valve is cracked with water coming out like a sprinkler once the plungers were opened. I have ordered new parts but in the mean time I am afraid to turn on the pump. Do I go ahead & add the salt? I don't want the water to turn green while sitting in the sun, the water has nothing added to it at this moment.
    I don't have a pool cover or a sump pump to circulate. I've read about adding chlorine but I haven't even added the salt! What do I need to do until the pump pieces arrive?
    chiefwej
    19k gallon Pebble Tec pool/spa, 2 hp Super II pump (x2), Aqua Rite T-15 SWG, Pro Grid 60 DE filter, Hayward H400 & Solar heating
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: swg pool filled, about to add salt but pump can't work!!
    Pull it out and take the valve to HD and find a plug that will fit the hole. Screw it in half way and turn on the pump and bleed the air out then screw it all the way in. That should get you by till then.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Quote Originally Posted by maxepr1
    Thank you! I'm heading there right now! My husband hates setting up the pool & anything to postpone he will do, lol!
    chiefwej
