Thread: Adding salt to a non salt water pool
    Mar 2010
    Spring, TX
    1,082
    If I was interested in doing this, what is the best way to go about doing it. Dump in filter, in front of a jet, etc? Also how often do you have to add the salt to keep it up or can it just be a one time thing?
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: Adding salt to a non salt water pool
    When adding salt for feel, 2,000 ppm is a good level to aim for. It is best to get an initial salt reading, since salt will never start at zero and there is no point in adding too much.
    You usually only need to add more salt once per season. The level will go down very slowly due to splash out and winterizing.
    You can simply dump the salt into the pool and then run the pump for 24 hours.
    Mar 2010
    Spring, TX
    1,082
    When I said filter I meant skimmer sorry. Is the pool store a good tester for salt levels or do I need to get my own test?
    Thanks.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Nope...no skimmer. I just get the blue mortons water softner salt bags (99% pure salt) and walk around the pool while pouring it in. If I recall your pool is pretty new and the pool store would be just fine for what you are looking to achieve, given there is no huge risk if you over shoot it by 500ppm.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by dmanb2b
    Actually I am not sure what the age is on my pool. I may give it a try.
    WE just slice the bag and let it sit on the steps. It is gone by the next day. We have a vinyl pool.
    Kply
    35,000 In-Ground Concrete/Plaster with spillover spa.
