Thread: Should I lower TA?
    Should I lower TA?
    I have finally gotten to the point of passing the overnight FC test, and now am focusing on other readings. I've been aerating to bring ph up from 6.8 to now 7.4. My TA is 200.
    Should I worry about bringing the TA down with muriatic acid? It's my understanding that I don't need to worry about calcium scaling from a high TA since I have a vinyl liner.
    Need a little guidance, please, and thank you!
    TF50 test kit
    9800 gal.
    15x25 oval; AG
    Hayward sand filter with zeobrite; Hayward pump 1hp pro-max flow, or something like that, LOL!
    Southwest MO; hot/humid summers, full sun 8am-1pm, then shading begins.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Should I lower TA?
    As long as you are not having to lower your pH so often that is very annoying, you can just leave it alone.
    The TA will come down on its own over time as you lower the pH.
    ETA: Congrats on passing the OFCLT
    You're done SLAMing when:
    Calcium scale is always a risk in any pool. Pools with a vinyl liner are fine with extremely low CH levels, but they run the same risks with high CH levels that any other pool does.
    Unless you are having problems with the PH going up very rapidly, I suggest you simply lower PH to 7.2 any time it gets to 7.8 until your TA level is more reasonable.
    Thanks to you both.
    I haven't even tested for Calcium Hardness. Guess I better do that just in case.
    As long as CH is in range, I'll keep an eye on pH until it gets to 7.8 and then lower to 7.2 and aerate.
    Thanks again!
    TF50 test kit
    9800 gal.
    15x25 oval; AG
