I should know this but...
ethany
564
Trenton NJ
A year goes by and I forget how to balance my water when first openning. I put 7 lbs of cya in the past few days. I was reading 0 when I opened pool. I seem to be holding some chlorine overnite. I now have 2ppm of fc and .5 of cc.
How do I shock when I have a cya of 0. I went to the chart and there is no 0 for a cya reading so I can't come up with a good multiplier for shocking.
The water is cloudy and a light green. Cannot see the bottom, maybe a little in the low end. I been brushing and backwash when needed. Just got done vacuum and now I am at a loss of what to do next.
My ph is 7.5 and ta is 60. Any advice?
4 out of the 7 lbs. is still in the sock in front of the return. The 3 lbs. is in pool now for a few days but I did backwash a few times. So since I cannot get a cya reading yet, what should I assume I have?
Well, I'm gonna guess that you got about 3 lbs in the pool.
If you also added it via sock method, then the backwashing didn't remove much of it.
You should get a second opinion soon :)
