Thread: Short on CYA reagent?
    Mar 2011
    Lower Bucks County,PA
    65
    Doing final test on cya before Vacation after last tweek. Have +/- 5ml left?-add 5ml water -do test. Shooting for +/- 45 so there should be enough for mark but don't know if results from mixture will work. HTH test kit being used. Thanks.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Re: Short on CYA reagent?
    As long as you mix equal amounts of pool water and CYA reagent together and there is enough liquid to make the black dot disappear, the test results are valid.
    Mar 2011
    65
    Looking for CYA reagent to use in my HTH test kit and am coming up empty. Are others compatible with the kit , hate to order on-line , and is there any cross referance chart on site to show substitution.Thanks
    Hi-Flo 2sp 1hp pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Taylor r-0013
    TFtestkits.net has it if it's not avail locally. FWIW, TFtestkits is owned by the same great people that own this forum/resource
