Thread: High FC Reading
    High FC Reading
    Thanks so much for the help with clearing my swamp. After weeks using tons of bleach, scrubbing, removing debris and testing, I finally have a blue pool that is rapidly clearing up. I brought the pool to shock level one last time yesterday and it held an FC reading of 25 overnight. CYA is 40. Is it safe to get in the pool with a reading that high? Do I need to just keep filtering and wait a few days for the levels to drop to the normal range before getting in?
    Florida Pool:Above Ground, 15,200 gallons, Cartridge, Vinyl Liner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: High FC Reading
    Generally, with an FC level any where below the shock value for your CYA level is safe to get in. Florida sunshine should drop it pretty quickly. If you're done shocking, you can "cheat" a little and replace a couple of inches of water to lower FC.
    Re: High FC Reading
    I am hoping this means my algae is gone - I am going to keep an eye on it and keep testing.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: High FC Reading
    If your CC is .5 or lower and your FC drops below 16 (shock level for your CYA of 40), as Woodyp said, it is okay to swim..
    Not quite sure from your description, but have you finished shocking? See red info in my sig.
    You're done SLAMing when:
    Re: High FC Reading
    I held an FC of 25 all day yesterday and overnight. I've been battling this algae for a few weeks - I think I finally beat it!
